Neck Setting Aid http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=42943 |
Page 1 of 2 |
Author: | Colin North [ Tue Mar 11, 2014 3:10 am ] |
Post subject: | Re: Neck Setting Aid |
Excellent tip. |
Author: | Arnt Rian [ Tue Mar 11, 2014 4:33 am ] |
I like it, thanks for the tip |
Author: | bftobin [ Tue Mar 11, 2014 7:57 am ] |
I really like that !!! Thanks Brent |
Author: | Joe Sallis [ Tue Mar 11, 2014 9:00 am ] |
good one |
Author: | Haans [ Tue Mar 11, 2014 9:25 am ] |
Nice jig Terry, might even extend it out to the bridge. |
Author: | George L [ Tue Mar 11, 2014 9:29 am ] |
Simple, clever, brilliant! Thanks for sharing. |
Author: | cphanna [ Tue Mar 11, 2014 10:15 am ] |
I agree. It's a great idea. Every time I see something like this I slap my forehead and think to myself: "Why didn't I think of that?" Patrick |
Author: | Michael Lloyd [ Tue Mar 11, 2014 11:29 am ] |
Ditto, great idea and thanks for sharing! |
Author: | Link Van Cleave [ Tue Mar 11, 2014 11:37 am ] |
Nice. I like it. L. |
Author: | Terence Kennedy [ Tue Mar 11, 2014 1:50 pm ] |
Thanks all. I've been building since 1998 and this idea just hit me recently while I was setting a neck. It's been a huge time saver. Like Patrick said, it was one of those "why didn't I think of this sooner" moments. Haans I do have a long centerline finder that keys into the truss rod slot. I bought a centerline finder from Tracy when he first made them at Luthier Suppliers ( http://www.luthiersuppliers.com/products/p9.html ) and there was a defect and he sent me another. I set up the first with pins to use as an alignment tool that used the truss rod slot. ![]() |
Author: | Tom West [ Tue Mar 11, 2014 2:56 pm ] |
Terence: Super tip......................!!! Tom |
Author: | ernie [ Tue Mar 11, 2014 4:48 pm ] |
Terrence i am going to use this idea vy clever and thank you. .Heel sanding is such a pita |
Author: | Tim L [ Tue Mar 11, 2014 6:33 pm ] |
That's a great idea |
Author: | Clay S. [ Tue Mar 11, 2014 8:02 pm ] |
Good idea, Thanks! |
Author: | Haans [ Wed Mar 12, 2014 7:17 am ] |
Looks like that will work for dovetails too. Need to get some more plexi... Thanks, Terry! |
Author: | Joe Sallis [ Wed Mar 12, 2014 8:10 am ] |
Terence Kennedy wrote: Thanks all. I've been building since 1998 and this idea just hit me recently while I was setting a neck. It's been a huge time saver. Like Patrick said, it was one of those "why didn't I think of this sooner" moments. Haans I do have a long centerline finder that keys into the truss rod slot. I bought a centerline finder from Tracy when he first made them at Luthier Suppliers ( http://www.luthiersuppliers.com/products/p9.html ) and there was a defect and he sent me another. I set up the first with pins to use as an alignment tool that used the truss rod slot. ![]() Terence, that's much the same as I do. I use the same method to locate the bridge (I'll try to remember to take photo tonight). But the idea of cutting out slots on the side to floss the neck joint without having to take the acrylic on and off is the sort of small detail that gets me excited. thanks |
Author: | Pat Foster [ Wed Mar 12, 2014 8:13 am ] |
Great ideas! Thanks, Terence! Pat |
Author: | Joe Sallis [ Wed Mar 12, 2014 8:20 am ] |
I feel compelled to add some advise to anyone who is going to make something similar. I used 9mm acrylic I found, cut to width on table saw and centre line scored with a marking gauge. What had me baffled for a time was that if you put the acrylic in place with pins in the truss rod slot and check the centre line reading then turn the acrylic over and check again, you get different readings. Now I always make sure that the line I made with the marking gauge is facing down. Otherwise, because of the 9mm thickness of the acrylic, if the line was on top you could only accurately read it if you looked directly down onto it. Hope this makes sense. |
Author: | Tim L [ Wed Mar 12, 2014 11:25 am ] |
Joe, The term for that is parallax error. That is common whenever the measured piece sits away from the measuring tool. Real common with optical measurement and kinda like looking at something with just one eye and then switching to the other eye. If you scribe a line on both sides of the acrylic it makes it easier to make sure you are on target. |
Author: | Joe Sallis [ Wed Mar 12, 2014 11:33 am ] |
Tim L wrote: Joe, The term for that is parallax error. That is common whenever the measured piece sits away from the measuring tool. Real common with optical measurement and kinda like looking at something with just one eye and then switching to the other eye. If you scribe a line on both sides of the acrylic it makes it easier to make sure you are on target. Good to know, thanks Tim. For a while I did wonder if either my straight edge was off or my technique with the marking gauge need some improvement. |
Author: | ChuckH [ Mon Mar 17, 2014 10:48 pm ] |
Brilliant !!! Sent from my iPad using Tapatalk |
Author: | ernie [ Tue Mar 18, 2014 9:22 am ] |
Glad you found the thread hutch !! |
Author: | James Ringelspaugh [ Tue Mar 18, 2014 10:10 am ] |
Ha, I was fitting a neck yesterday and trying to think of a way to make things easier at the fretboard side of the heel. This looks simple and perfect for the job. |
Author: | uvh sam [ Tue Mar 18, 2014 6:59 pm ] |
What do you do if the fretboard doesn't go on dead center? |
